Quota problem when reate user with 8.0.2
When we create a new user, with 500MO quota and 400MO warning, mailbox is created with 500GO quota and 400GO warning. Work fine with 8.0.1 !!!
Subject: we have the same problem
we have exactly the same problem here .
Subject: Not unique to user creation
I have a mixed release environment, and have mail databases on servers running 7.0.3 that have quotas that have flipped from MB to GB. Admin server for Address book was upgraded to 8.0.2 recently and this has been happening since then. Will open PMR with IBM.
Subject: Please log this potential issue with Lotus Support so it can be investigated <>
Subject: 8.0.2 Quota MB becomes GB
Has anyone logged a PMR with IBM on this? I just noticed this on all users we have created since upgrading to Domino 8.0.2.
Subject: IBM is creating an SPR for this
I just got off the phone with IBM Support. they are creating an SPR for this issue. Once I get the SPR, I will update the thread.
Note that this is only happening when you select the option to create the file in the background. Is something that AdminP is doing. If you uncheck the box to create in the background, this does not appear to be an issue.
Subject: An SPR has been created for this issue
Here is the e-mail I received from the tech I talked to yesterday.
The spr # is RPOE7J38TA. I have added a customer report to the spr. The issue will be fixed in 8.5. If you have any additional questions please do not hesitate to contact me. I hope you have a great day!
Kind regards,
Riccardo Catania
Software Engineer
IBM Software Group, Lotus
Technical Support Line: 1.800.426.7378
Subject: Have the same problem (MB → GB quota size)
Maybe this regression is effected by that modification:
http://www-01.ibm.com/support/docview.wss?uid=sim4290df5d1a509e2fc8525748f0003dd84
"SPR# WMUH7CHK55 - Fixed quota size for mail database quota size and warning threshold size on databases, when registering users using the C API.
Fixed in Release 8.0.2"
Subject: It’s only client side problem in 8.0.2 Domino Administrator client
8.0.1, 7.0.3 administrator clients are OK.But 8.0.2 translates quota and warning sizes in “Administration reauest” database into GBytes
