Questions RE: first web DB
I am working on my first Web application and have questions, not as to the code per se, but more WHERE the different pieces of code are placed.I would like the form to do the following:
A. User fills out ‘Request’ form (10 fields).
B. User clicks ‘Submit’ button which:
  1. Validates the fields using JS (in JSHeader); and
  2. Opens a ‘Thank You’ form which shows them a confirmation # (which is simply the last 8 characters of the UNID) and has a ‘Print Confirmation’ button.
C. The ‘MoveReqNum’ field on the ‘Request’ form should increment by 1 from the last request.
My ‘Submit’ button:
@Command([FileSave]) ;
@URLOpen(“http://fmbdev01/MoveReq.nsf/MRConfirm?OpenForm&UNID=” + ParentID) ;
@Command([FileCloseWindow])
In WebQuerySave:
I call the following agent to increment the Request #:
Dim S As New NotesSession
Dim Db As NotesDatabase
Dim V As NotesView
Dim Doc As NotesDocument
Dim NumDoc As NotesDocument
Set Db = S.CurrentDatabase
Set V = Db.GetView( “ConfirmNum” )
Set Doc = S.DocumentContext
Gosub assignNumber
Exit Sub
assignNumber: '- assign the next available # to request
If Doc.IsNewNote Then
Set NumDoc = V.GetFirstDocument
Num& = NumDoc.ConfirmNum(0)
NewNum& = Num& + 1
NumDoc.ConfirmNum = NewNum&
Call NumDoc.ComputeWithForm( False, False )
Call NumDoc.save( True, True )
Gosub populateNumber
Return
populateNumber:
Doc.MoveNum = NewNum&
Call Doc.Save( False, False )
QUESTIONS:
  • I have another agent that grabs the UNID and parses out the last 8 characters but I can’t get it into my Confirmation form.
  • Do listbox fields require different JS than text fields? I’m just checking that they’ve selected something!
  • My WQS agent fails, stating “unsupported function…” (It works in the client).
  • My ‘Print Confirmation’ button is not working; it’s simply @Command([FilePrintSetup]).
I’ve been trolling the Forums for a few days and have found lots of help with the actual code I need but I can’t seem to find anything that tells me what goes where!
Thanks in advance.
Subject: Questions RE: first web DB
In general, program that needs to be executed on the user interface on the web needs to be coded using javascript. Of course the WebQuerySave and WebQueryOpen should be coded using Lotus Script.
Do some googling to find out how to print and validate listbox using javascript.
