Question on "print" and "right" function
These are probably easy questions for the more experienced LotusScript developers, but since I’m not…
1/What instruction should I use to print out NEWDOC in below code?
2/ How can I only put the 5 most right digits of PFNumber into newdoc.PFNumber. (I always get a Type Mismatch).
doc.PFNumber is a “text” field , computed with following value:
“MC” + @Repeat(“0”;5 - @Length(@Trim(@Text(SeqNumber))))+ @Text(SeqNumber)
newdoc.PFNumber is also “text”, computed with value PFNumber.
Here’s the code:
Sub Click(Source As Button)
Dim ss As New NotesSession
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim newdoc As NotesDocument
Dim wk As New NotesUIWorkspace
Dim uidoc As NotesUIDocument
Dim PFnum As String
Set db=ss.currentdatabase
Set uidoc=wk.currentdocument
Set doc=uidoc.document
Set newdoc=New notesdocument(db)
newdoc.form="PrintLabel"
newdoc.PFShipTo1=doc.PFShipTo1
newdoc.PFShipTo2=doc.PFShipTo2
newdoc.PFShipTo3=doc.PFShipTo3
newdoc.PFShipTo4=doc.PFShipTo4
newdoc.PFShipTo5=doc.PFShipTo5
newdoc.PFShipTo6=doc.PFShipTo6
newdoc.PFNumber=doc.PFNumber
newdoc.PFtype=doc.PFtype
Call newdoc.save(False, True)
Call wk.EditDocument(True,newdoc)
Subject: RE: Question on “print” and “right” function
Herwin,
Re: the type mismatch, the line should read doc.PFNumber(0) as all fields are considered to be arrays (even if there is only one value in them)
To get the 5 right digits of the field, use the following…
newdoc.PFNumber=Right(doc.PFNumber(0),5)
HTH
Mike
Great!!!Thx for your quick response, Mike.
Any idea about the print?
All I can think is to have an agent that runs @Command([fileprint]) and then call the agent from your script
(You can;t evaluate @Commands in script)
Apart from that - have you searched the forum for ideas?
Subject: Printing
You cant print from a NotesDocument
but you can from a NoytesUIDocument
Dim uid as NotesUiDocument
set uid = wk.EditDocument(True,newdoc)
Call uid.Print( [ numCopies%, [, fromPage%, [, toPage%, [,draft ]]]] )
will automatically print to teh currently selected printer
call uid.Print
pops up the manual box
Subject: RE: Printing
grateful thanks!
