I am at the end of creating a workflow app. However due to business rules I need to change a field update procedure and this for some reason the function won’t work.
form 1: formProject
form 2: formCompletion
Document Locking is on.
All Lotusscript
While in a formProject based document(read mode) I create a document via LS with formCompletion (not a response). In the querysave event of the formCompletion I call a function (tried sub too) that will update a computed field on the original formProject document with a text value of completed. it works when the function is called from the querysave event of the formCompletion. However the customer wants the field updated when a manual notification email is sent out which is already in a button. I move the Function call from the querysave event to the button. since I have locking turned on I am testing to make sure the original document is not locked and it’s not in edit mode before updating. Once the function call is moved into the button that also launches an email, the function no longer works. No error is tripped. I followed debug and the field just never get’s set. Yes I am saving it. This function works when called from a querysave event but not in a button. It does work if I manually close the original (formProject) document in the background and then switch back to the formCompletion document and hit the button to send the email calls the update function.
I did a search in this forum but couldn’t find anything close to what I describe. Anyone have any suggestions?
