I was succefully passing the input values from one form to another form using “Query_String”, this success due to this forum only.
Now I am facing little bit problem. Actually I am passing three values empid, month, and year to other form. Then from query_string, I am extracting these three values to another 3 text fields (hidden fields). Using these 3 fields, I am sending these three to the other database, and getting dates into $list field.
Now what I am doing that I am selecting one date from the $list field, and then sending to the other datbase, to fetch some related values.
Here is the main problem, once I send the date value to the other database, I am getting the values, but due to refreshing , the dates are not displaying in $list field. But I want to send one by one dates, to get the values.
For this please give ur suggestion. Waiting with tensionious.
Rajan
Subject: Query_String problem, due to refresh
If I understand you, it sounds like when you initially open form2, you are able to extract the values from the query_string. But when you click on some field (a drop down list perhaps) to fetch additional data based on the query_string values passed, the act of refreshing wipes out the previous query_string values and causes subsequent lookups to fail. Do I understand the problem correctly?
Steve
Subject: RE: Query_String problem, due to refresh
Ys Cannon, that is my problem. U got my point. Pls give ur valuable suggestion
Okay. Basically what you want to do is intercept the refresh. Instead of setting your keyword field to refresh fields on keyword change, you call a function in the onChange event. Let’s call the function doRefresh().
The doRefresh() function will take your query_string variables and append them to the URL and then call the _doClick function which will do your refresh for you, but still preserve the original variables.
In pseudo code, it would look something like this:
doRefresh(){
var f = document.forms[0];
var empID = f.somefield.value;
var mon = f.someotherfield.value
var params = “”;
params += “&EMPID=” + empID + “&MONTH=” + mon;
_doClick(‘$Refresh’, this, ‘_self’, params);
HTH
Steve
