I just read your previous feedback (WEBB7J5C22) and I guess what you want is a way to customize Notes’s data folder path, am I right?
There’s not a simple fix to support this feature, we may need some additional code change and sufficient test to ensure the quality. So I’m not sure when we can fix this problem. But we’ll consider your request in 8.5.1 release.
For us it’s important to dissociate the application Lotus Notes Client from a physical computer.
Putting all Lotus Notes client & application settings on network instead remaining on local drive give us more possibilities ( Global strategies for easy Backup, and remote access to the application keeping personal settings for each user)
In windows version it’s possible change the local drive by a network drive, and now we start migrate to Mac Os X and we loose this feature.
We are happy to know you take care of our request and we hope this problem will be fixed and implemented in a future release.
