I was wondering if there was a way to protect certain tabs in a form so that only certain users could edit the fields within them. If not, what’s the best way to protect fields in the same way? I tried checking “Must have at least editor access to use” under security in the field properties, but it still allowed all users to modify the field. Any help would be greatly appreciated!
Subject: Protecting Tabs and/or Fields
Are you saying that users who are only Author in the ACL can edit those fields??? (Because that can’t happen.)
Subject: RE: Protecting Tabs and/or Fields
The controlled access section worked well, thanks! I’m not sure what was happening with the Editor Access thing, I may not have had my ACL set up right. Thanks again for the help.
You can’t protect them directly. What you’ll need to do is to create your tabbed table, fill in all the fields and such, and then, for each tab you want to protect, select its contents and turn them into a controlled access section.
Thanks for the reply, that should work great! 2 questions though, first, is there any special format for the Access Formula? I tried this code to filter based on my ACL but it didn’t work:@IsMember(“[ProductEngineer]”; @UserRoles)
Also, is there a way to make the section un-collapsable? Thanks again!
The access formula needs to evaluate to name(s) or role(s) (it’s not like a hide-when, more like an Authors or Readers field). The formula would just be “[ProductEngineer]”.
