Subject: @ProperCase Problem
Joe,
I have gone through that problem myself. Years ago I wrote my own proper case routine to handle the anomalies that came up. I have included it below, just copy and paste it into the (Declarations) area of a script library. The big advantage of the code below is that you can modify the behavior of the routine to the names you are working with.
If you send me your e-mail I can send you my library of routines, of which ProperCase is just one.
Hope this helps.
Ron
Class ProperCase
'This class proper cases a string by converting the first letter of each word to uppercase.
'In addition, also converts the letter following these characters " .,&-(<[" and it attempts
'to proper case names beginning with "Mc" (i.e. McCormick) and names where the second
'character is an apostrophe (i.e. O'Malley).
'By default, words are defined as space delimited strings. The string "P.O. Box 9999-12345"
'consists of three words. If the hyphen is included as a work break character then the,
'string "P.O. Box 9999-12345" would contain of four words.
'Properties:
' Exact = String. Read-write. String of tilde (~) separated words which are always
' returned as defined here. Default: "~PhD~".
' Lower = String. Read-write. String of tilde (~) separated words which are always
' returned as lowercase. Default: "~aka~a/k/a~dba~de~".
' LowerFirst = String. Read-write. When True, converts sString to lowercase before
' converting to proper case. Default: True.
' Upper = String. Read-write. String of tilde (~) separated words which are always
' returned as uppercase. Default: "~DDS~II~III~IV~MD~PO~".
' UpperNext = String. Read-write. String which triggers the NEXT character to be
' converted to uppercase. Default: " .,&-(<[".
' WordBreak = String. Read-write. Each character in the defined string denotes a word
' break. Default: " ".
'Methods (Private):
'Methods (Public):
' New Instantiates the object and initializes default values.
' Result Pass a string to be converted to propercase. The converted string will be returned.
'Databases:
'Views:
'Examples:
' Dim oPCase As New ProperCase
' oPCase.LowerFirst = False
' oPCase.Result("santa claus") 'Returns "Santa Claus"
' oPCase.Result("jean-claude vanDamm") 'Returns "Jean-Claude VanDamm"
' oPCase.LowerFirst = True
' oPCase.Result("jean-claude vanDamm") 'Returns "Jean-Claude Vandamm"
' oPCase.Result("A. O'MALLEY") 'Returns "A. O'Malley"
' oPCase.Result("p.o. box 123") 'Returns "P.O. Box 123"
' oPCase.Result("mccormick spices") 'Returns "McCormick Spices"
' oPCase.Result("a. smith iii, esq.") 'Returns "A. Smith III, Esq."
'Class Objects:
Private bFirst As Boolean
Private sBreak As String
Private sExact As String
Private sLower As String
Private sNext As String
Private sUpper As String
'Properties:
Public Property Get Exact As String
Exact = sExact
End Property
Public Property Set Exact As String
sExact = Exact
End Property
Public Property Get Lower As String
Lower = sLower
End Property
Public Property Set Lower As String
sLower = Lower
End Property
Public Property Get LowerFirst As Boolean
LowerFirst = bFirst
End Property
Public Property Set LowerFirst As Boolean
bFirst = LowerFirst
End Property
Public Property Get Upper As String
Upper = sUpper
End Property
Public Property Set Upper As String
sUpper = Upper
End Property
Public Property Get UpperNext As String
UpperNext = sNext
End Property
Public Property Set UpperNext As String
sNext = UpperNext
End Property
Public Property Get WordBreak As String
WordBreak = sBreak
End Property
Public Property Set WordBreak As String
sBreak = WordBreak
End Property
'Constructor:
Sub New
'Set default values.
bFirst = True 'Convert to lowercase first.
sBreak = " " 'Word break character(s).
sExact = "~PhD~" 'Return exactly as is.
sLower = "~aka~a/k/a~dba~de~" 'Return in lowercase.
sNext = " .,&-(<[" 'Capitalize next character.
sUpper = "~DDS~II~III~IV~MD~PO~" 'Return in uppercase.
'Destructor:
Sub Delete
'Methods (Private):
'Methods (Public):
Public Function Result(Byval sString As String) As String
'Pass the string to be converted. The return string will be converted to propercase
'according the properties defined.
Dim iCntr As Integer
Dim iPos As Integer
Dim iTemp As Integer
Dim sChr As String
Dim sLast As String
Dim sNew As String
Dim sSuffix As String
Dim sTemp As String
Dim sWord As String
sNew = ""
If Me.LowerFirst Then sString = Lcase(sString)
'First compare the entire string against the special test cases (exact, all lower, and
'all upper). This test is mostly for names, a person with the last name of "de la Garza"
'may prefer it to be "De La Garza". Note that the first match wins.
sTemp = "~" & sString & "~"
If Len(sString) > 0 And Len(sTemp) <= Len(Me.Exact) Then
If Instr(1, Me.Exact, sTemp, 5) Then 'Special case words will be returned exactly as specified.
sNew = Mid(Me.Exact, Instr(1, Me.Exact, sTemp, 5) + 1)
sNew = Left(sNew, Instr(1, sNew, "~", 5) - 1)
sString = ""
If Len(sString) > 0 And Len(sTemp) <= Len(Me.Lower) Then
If Instr(1, Me.Lower, sTemp, 5) Then 'Word is to be returned all lowercase.
sNew = Lcase(sString)
sString = ""
If Len(sString) > 0 And Len(sTemp) <= Len(Me.Upper) Then
If Instr(1, Me.Upper, sTemp, 5) Then 'Word is to be returned all uppercase.
sNew = Ucase(sString)
sString = ""
'If the word (sString) was not formatted above, extract and test each word individually.
Do While Len(sString) > 0
'Extract the next word from the string. Words are delineated by the defined break
'characters. If multiple break characters are defined, the one that is found first
'will be used. If no break characters are found, the remaining string will be
'treated as a single word.
iPos = 0
sWord = ""
For iCntr = 1 To Len(Me.WordBreak)
sChr = Mid(Me.WordBreak, iCntr, 1)
iTemp = Instr(1, sString, sChr, 5)
If iTemp > 0 And (iPos = 0 Or iTemp < iPos) Then iPos = iTemp
Next
If iPos = 0 Then 'No break character, so treat the
sWord = sString ' remaining string as a word.
sString = "" 'Clear the string.
Else
sWord = Left(sString, iPos) 'Extract the next word and
sString = Mid(sString, iPos + 1) ' remove it from the string.
If Len(sWord) = 1 And Instr(1, sWord, Me.WordBreak, 5) Then 'The "word" is simply a break character,
sNew = sNew & sWord ' so append it to the new string.
Else
'Save off any trailing characters (spaces, commas, periods, etc.) leaving just
'the "word" to use for comparisons and processing.
sSuffix = ""
For iCntr = Len(sWord) To 1 Step -1
sChr = Mid(sWord, iCntr, 1)
If sChr Like "[a-zA-Z]" Then
Exit For
Else
sSuffix = sChr & sSuffix
Next
sWord = Left(sWord, iCntr)
sTemp = "~" & sWord & "~" 'Test the word against the spacial case lists.
sTemp = Mid(Me.Exact, Instr(1, Me.Exact, sTemp, 5) + 1)
sTemp = Left(sTemp, Instr(1, sTemp, "~", 5) - 1)
Elseif Instr(1, Me.Lower, sTemp, 5) Then 'Word is to be returned all lowercase.
sTemp = Lcase(sWord)
Elseif Instr(1, Me.Upper, sTemp, 5) Then 'Word is to be returned all uppercase.
sTemp = Ucase(sWord)
Else
iTemp = Len(sWord)
sLast = ""
sTemp = ""
For iCntr = 1 To iTemp
'Do the tests only if it is a lower case letter (they are the only
'characters that can be uppercased).
sChr = Mid(sWord, iCntr, 1) 'Extract the next character from the word.
If sChr Like "[a-z]" Then
If iCntr = 1 Or Instr(1, Me.UpperNext, sLast, 5) Then
'If it is the first character or the last character is one
'of those listed, uppercase the current character.
sChr = Ucase(sChr)
Elseif Len(sTemp) = 2 Then 'Test the last two characters processed.
'This propercases names such as McCormick.
If Right(sTemp, 2) = "Mc" Then sChr = Ucase(sChr)
'This propercases names such as O'Malley and D'Shea.
If Right(sTemp, 1) = "'" Then sChr = Ucase(sChr)
sLast = sChr
sTemp = sTemp & sChr
Next
sNew = sNew & sTemp & sSuffix 'Append the word just processed to the new string.
Loop
Result = sNew 'Return the new string.
End Function
End Class
