@prompt Help
Hello if yes I want to compose a form if No I wish to close the prompt box
Can someone help with syntax please
How do I get the prompt box to close if No is chosen
Thankyou
@Prompt([YesNo]; "Have You Blah Blah? " ;
"Blah Blah Blah etc etc etc ");
@Command([Compose] ; “formName”; if no close the dialogue box
Subject: @prompt Help
Hi Maggie,
This piece of code would do…
@If ( @Prompt([yesno] ; “Prompt Title” ; “Do you want to open the form?” ) ; @Command( [Compose] ; “form name” ) ; “”)
Regards,
Bruno.
Have you read the designer help? All most all the functions have examples on how they can be used.
var:=@Prompt([YesNo]; “Have You Blah Blah?”;"Blah Blah Blah etc etc etc ");
@If(var=1;@Command([Compose];“FormName”);“”);
cheers!!
Ashish
