Project Management
Hi Everyone, I am looking for an Opensource solution to project management. Does anyone know of any free notes product that will help me out ?
Any help is appreciated. Thanks
Subject: Coming Soon
I’m working on a pure XPages application right now that will do some Project/Task/Comment/Time tracking.
I’ll be putting it on my website and very likely openNTF as well in early August right after the IamLUG event in St. Louis.
Like Chris said - I’d be interested in what you’re looking for and why.
Subject: The reason you seek
We are looking for a simple Gantt Chart that will somehow tie into a user’s calander as well. We are really not looking for a full blown Project Management so instead of buying MS Project for silly $$$ and only using the Gantt Chart, I wanted to explore the opensource market.
Keeping it in Notes is also important so our Mac users and PC users can share the Data easily.
Subject: Well
I’ll tell you this…I have something coming out at some point. how fleshed out the initial version is remains to be seen. I’ve at least looked at / thought about the possibility of trying to integrate http://www.jsgantt.com/ into the application to show the tasks and subtasks.
Since this is an XPage only app I’ve not given any thought to calendar integration.
But I have something coming out soon…
Subject: There are several projects on OpenNTF.org
… that might address your needs.
Also, curious: Is it the price of the project management apps that’s making you go “opensource” or are you looking for coding examples etc.?
HTH,
-Chris
