Programmatically setting Count and Start for a view
I have a form with an embedded view on it, I wish to drop the “first” document from the view, BUT, I can’t use &Start=2 on the QueryString
Is there another way to “set” &Count and &Start without having to put them on the QueryString?
I wish to do something like if the Query_string has &Lead on it, set Count=100 and Start=2 but not actually put them on the querystring, so it happens on the form…
Cheers
Ad
Subject: Programmatically setting Count and Start for a view
Yes you can use &start=2 plus all other view arguements on an embedded view in a form but in order to do so you must use ?OpenView instead of ?OpenForm or ?ReadForm in your URL to access the form with the embedded view.
HTH
Subject: RE: Programmatically setting Count and Start for a view
Hi Melissa,
Hmm I’m not sure thats right, what I want to do is NOT put &Start=2 on the QueryString but instead somehow do it programmatically on the Form.
So if the query string looked like
/db.nsf/form?ReadForm&Lead&cat=xxx
I already use the “show single category” to compute off &cat on the querystring, but I wish to be able to somehow tell the embedded view to set it’s &Start=2&Count=100 but not have to do it on the querystring…
Pity there isn’t a $Start or some other field I can put on my form that the embedded view with look at?
So I guess I’m asking if anyone knows of a way to do it?
Put it in the query string and adjust your category formula to exclude “&start=…” from the right of the string.
I don’t think that you can do this using fields on the form
