We keep getting the error - "Failed to fetch the forms" when our search criteria use a date field.
For example:
- where date field after 01/01/2020
- where date field between 01/01/2019 and 01/01/2020
We can create Filters on TEXT and Dropdown fields (Although it would be helpful if the filter prompted the user for options available to search for when it’s a dropdown field)
**Note** We imported records into the Volt applications from a spreadsheet.
Not all records imported have dates (the date column was left empty on multiple rows). When we check the field type with the HCL Notes client, the field is showing as TEXT where cell imported were blank and where a date has been imported they are correctly showing as DATE/TIME fields. (Unsure if this is related to the problem).
Also related to filters, is it possible to search a MULTI-LINE-TEXT field where it 'CONTAINS' a particular value, filters only offer 'Equals' or 'Does Not Equal' and Wildcards don't seem to work. Would be great if we could add a search bar like the Notes Client.
We have Domino 11.x installed on Windows with Volt 1.0.1.
Thanks in advance for any suggestions...
