Problems with Views. I deleted a view called AccountInfo ... now whenever i open project in Notes, it says views not found. Its not a default view
Problems with Views. I deleted a view called AccountInfo … now whenever i open project in Notes, it says view “AccountInfo” not found. Its not a default view, Can you tell me why this error is popping up and how i can get rid of it … its really very strange …
Regards,
Jawad
Subject: Problems with Views. I deleted a view called AccountInfo … now whenever i open project in Notes, it says views not found. Its not a default view
It’s probably used on a navigator, page, …
What are the launch properties of the database (“rocket” tab) ?
Start by checking the design elements that are used when openening the database.
