Problems with Outline Java Applet
The following problems have been observed for a web app developed using Designer 5.0.11 running on 6.0.3 CF2. Anyone know if these are fixed with 6.5?
  1. Font attributes (esp bold) for outline entries are not being honoured on first level (second level not tested).
  2. Vertical scroll bar only performs line up/down when page up/down expected.
  3. Scroll bar does not always hide when outline fits within frame (as if outline dimensions not being honoured).
Thanks in anticipation,
Richard Gray
Canberra
Subject: Problems with Outline Java Applet
I have had a similar problem about a year ago while I was working with Designer 5.0.10 and a 6.0 Domino (Beta).
Designs from one would not display is cascade and seemed to display the same type of symptoms as you describe.
I noticed that once the design was synchronised to one release, that is 6.0 (in my case) everything that was a problem went away.
I think as long as you do this type of cross version development you will find some funnies.
Rolf Pfotenhauer
Software Engineer
email: rolfpf@yahoo.com.au
