Problems with Notes 8.5.1 on Ubuntu 9.10 Karmic 64-bit
I have used this howto to install
Is anyone experiencing these problems?
Widget “drag to install” does not work
Trying to install widgets using “drag to install” is not working. Have tried the LinkedIn widget at http://www.linkedin.com/lotus and also the Symphony sidenote plugin at http://symphony.lotus.com/software/lotus/symphony/plugin.nsf/web_DisplayPlugin?openform&unid=8F3F6FAE6DDF0A0F852574B3002AF8D8
Used the LinkedIn plugin in 8.5.1 on Ubuntu 9.04 with no problems.
Have to clieck a ‘Dialog list’ button twice
to make the list dialogue appear.
Also: Could any of you describe how to install 32 bit theme engine? (as noted here )
I know Lotus Notes is not supported on either 9.04 nor 9.10 and especially not when running 64 bit OS, but anyway…
