Problems with "monetary format "
Hi :
I have a number field with the next monetary format:
x…x.xxx,xx €; that is I use “,” to separate two decimals and “.” to separete miles.
When I show a column in a view with this field , the result is a number but without decimals:
Ex: 12.897 €
I don´t know why.
Is there a simple solution for that?
Thanks in advance,
Sonia
Subject: problems with "monetary format "
Check the column properties Advanced Format tab (4th tab). Provide same style as field has on the form.
Hi Sonia,Try this: check the column property called “Advanced Format” (the 4th), select the style “Number” and then force the decimal places to 2.
Bye,Stefano
Subject: RE: problems with "monetary format "
Perfect, problem solved !!!.
Thank you very much,
Sonia
