Problems with login to verse on premise after first logout
Hello,
on one Domino Server (V10 FP4 /VOP 2.0) we have problems with users, when they try to reconnect to verse on premise without shutting the whole browser (Firefox / Edge) after they have sucessfully logged out. The Login-dialog is not presented, but the browser tries to open directly the mail-db. With Chrome this behaviour is not observed.
Another Domino Server with the same configuration shows no problems with redirection to the login-form.
Any hints?
Harald
Hello Harald,
Please check the below document which will help to resolve the issue.
Verse 2.0 does not prompt for login page when session expires
https://support.hcltechsw.com/csm?id=kb_article&sysparm_article=KB0081102
Thank you
Regards
Shrikant J
Hello Shrikant,
i put the parameter DOMINO_FORCE401_WITH_HTML_LOGIN_PAGE=1 into the notes.ini.
But the behaviour is even worse. Now in Firefox you get the error every time, even closing the browser does not help. With Chrome there is still no problem.
Any further hints?
Thank you
Harald
Hello Harald,
Thanks for your feedback and sorry to know that it has created a problem with the said parameter on Firefox. Let me check the behavior on my test server with Domino 10.0.1 FP4 with Verse 2.0.
I assume that you are using mail file design derived from the mail9FP9.ntf template or a later version for Verse 2.0.
This parameter has worked for other customers for the login page issue. For the time being you can disable the parameter as it is giving problem.
Will keep you posted.
Thank you.
Regards
Shrikant J
Hello Shrikant,
yes the mailfile designs are 9.0.1. FP9 or 10.0.1.
I will set the parameter to 0.
Thank you and regards
Harald
Hello Herald,
I tested on Domino 10.0.1FP4 with Verse 2.0. I see login page appear after logout did close the browser and access the Verse url has prompted for the username and password.
I used both Firefox and Chrome browser for my testing.
I have attached a video of my testing in this response. Please let me know your comments if I missing something in testing the issue similar yours.
If investigation is required I would request you to please open support case. So that we can collaborate with the development team if needed.
video file of my testing you can download it from here.
Thank you.
Regards
Shrikant J
Hello Shrikant,
the video shows exact the behaviour of our other Domino-Server with 10.0.1 FP4 /Verse 2.0 and the same behaviour the Domino-Server shows with Chrome!
Meanwhile i'm searching for the difference between the two servers. All that i found so far, was nothing! But the server with the problems now opens the Login window in a new tab. I will continue to search the difference.
Thank you.
Regards
Harald
Hello Harald,
Thanks for your response. Will further wait for your update. Please consider the following to verify one which is working and non working.
1) notes.ini file for any parameter difference.
2) domcfg/web redirect database settings.
3) Server document/Internt Site and SSO document.
Thank you.
Regards
Shrikant J
Hello Shrikant,
just to give a small update:
First i updatted my servers to 10.0.1 FP5 but this did not change anything. The domcfg and web redirect databases, the internet Site-documents and SS0 LTPA-Token seemed to have the same configuration.
It even got worse after an update of Chrome to Version 85.x! The users could not log in even after setting the above notes.ini parameter to 1. It seemed that the browser session alway tries to open the last mailfile and while the user was not logged in, the verse engine tried to get anonymous access on the mailfile and got stuck in a loop and was not displaying the loggin-Form!
I now have a workaround putting this into the notes.ini:
iNotes_WA_LogoutRedirect=https://myserver.mydomain/homepage.nsf/IntroNeu
I "designed" a new page and put a hotspot link on it to https://myserver.mydomain/verse. So after the user logged out, this page is displayed and if the user wants to log in again, he just hits the link and gets the login-Form. It is working now for about two days (keeping finger crossed) on Firefox and Chrome.
Regards,
Harald
Hello Herald,
Thanks for the update and good to know you have a workaround by redirecting the logout URL using the ini iNotes_WA_LogoutRedirect.
However, the suggested below ini parameter DOMINO_FORCE401_WITH_HTML_LOGIN_PAGE=1
has worked for other customers not sure why with only that parameter has not worked. May be its an environment specific. I hope you already had created a support case for this to understand by having some debug traces to understand where it is breaking.
Thank you again for keeping me updated on the issue.
Regards
Shrikant J
