Problems with LDAP queries against Domino Directory
HiI have enabled my domino directory to be published as ldap and available for anonymous queries
If I run
ldapsearch -h myldaphost cn=*
I get a list of all entries, and a person is i.e.:
CN=FirstName LastName,O=DominoCertifier
objectclass=dominoPerson
cn=FirstName LastName
uid=userid
so far so good,
I would suppose that I could query my ldap with something like:
ldapsearch -h myldaphost O=DominoCertifier
and get a list of all entries that have that certifier (including my user. But that does not work, the query returns only 1 entry for the certifier.
I tried using a more complex filter like
ldapsearch -h myldaphost “(&(cn=*)(O=DominoCertifier))”
This in my opinion should return all entries with the above mentioned certifier, but it returns nothing.
I am missing something? Do I need to enable somthing on ldap or domino directory to peform this kind of query?
/Andreas
Subject: Problems with LDAP queries against Domino Directory
If I run
uid=userid
so far so good,
There are 3 parts that determines the objects to return from an LDAP search
scope
base
filter
Try ldapsearch with no arguments to get its help.
In your example above, you are only specifying a filter. To perform your search for all objects under O=DominoCertfier, simply re-use your initial search with the O=DominoCertifier as the base. i.e.,
ldapsearch -h myldaphsost -b “o=dominocertifier” “cn=*”
Subject: RE: Problems with LDAP queries against Domino Directory
Thanks for the explanation
