Hello,
I am having problems with the method Getentrybykey of the NotesView class. I have to say, that i searched this Forum for a solution but none of the former postings descrives my problem.
i am using the following code in a hotspot button
Dim tsl as Notesviewentry
Set view= db.GetView("bamaconflict")
Set tsl = view.GetEntryByKey("56112")
GetEntryByKey is not returning anything.
the view “bamaconflict” exists, an has a column which is indexed, this column is also the first column of the view. The document containing the key “56112” also exists. i really don’t know what i am doing wrong.
I already debugged the script with the lotus script debugger, but the only thing i see, is that i am not geting any value after calling GetEntrybyKey.
the Column in the view displays the value of a text Field.
TAI
Salvador
