Problems with @for
I posted an question yesterday about @subset, and thought overnight about replacing it, even simplifying it, using an @for loop. Yet again, strange problems I just can’t figure out.
Below is my code
s_1 := @TextToNumber(@Text(Start));
s := @If(@IsError(s_1); 1 ; s_1= 0; 1; s_1);
c_1 := @TextToNumber(@Text(Count));
c := @If(@IsError(c_1); 1; c_1 = 0; 1; c_1);
h := @TextToNumber(@Text(TotalHits));
pages := @If(c = 0; 1; @If(@Integer(h/c)<(h/c); @Integer(h/c)+1; @Integer(h/c)));
curpage := @If(c = 0; 1; @Integer(s/c) = 0; 1; @Integer(s/c) < (s/c); @Integer(s/c) + 1; @Integer(s/c));
tmp:=pages;
x:=1;
@For(x:=1;x<=tmp;x:=x+1;
html:=html+@ReplaceSubstring(nhtml[x];"***";@Text(x))
html+" "+@Text(tmp)
This code is to display how many pages there are in search results, h is the total amount of results returned and c is the number of results to display on each pages.
Now, if I replace the x<=tmp with the x<=3 or even make tmp:=3; (which it computes to in my example), it works fine BUT if I use the pages variable, it seems if the @for loop goes into an infinite loop - I get the error in the browser
Error 500
HTTP Web Server: Lotus Notes Exception - The formula has exceeded the maximum allowable memory usage.
I’m going nuts here, please can someone suggest something.
Thanks,
Cameron
Subject: Do you have a Field called “pages” on your Form? If you change the name of the var to “pg1” or something does it still fail?
