Hello all,
I had a strange situation in my db. I have to create folders programatically using LotusScript but after I create them they do not appear in outline. I try to find some refresh method which will do it for me, but I can’t find any.
Can anyone point me how to do it.
Subject: Problems with folders
If the outline does not contain a Other Folders placeholder, it doesn’t show up automatically.
johan@kanngard.net
http://dev.kanngard.net
Subject: RE: Problems with folders
This outline is standard mail outline. This db is based on mail6 template. Whan I create folder using Create Folder Action - everything is ok and folder appear in the folder tree. But programatically it isn’t showed there.
It isn’t supposed to be. The “Other Folders” entry in an outline displays folders that are not hidden but have not been added to the outline.
Subject: Problems with folders -
So there is no way to get the “other folders” via outline classes/methods.
It would be a nice thing, to be able to build a web-based menu-navigation using “other folders” by simply drag & drop folders/create new and then create nav.
i’ll guess the other way is to use view-classes.
/l
Subject: RE: Problems with folders -
Why create nav? Other Folders and Other Views are automatically populated, so why would you need to populate them yourself?
Subject: Problems with folders ?
i would like to make the web-menu-navigation in my cms based on the folders i make in the “other folders”.
Why?
Because you dont need a designer in order to add new entries. It’s easier to maintain a tree-structure by drag/drop.
The folders can be made with a notes-client and it’s very notes-mail like. Also there are some web-supported @formulas for this folders aswell.
Sure there are some caveats, but hey isnt it always
/l
Subject: RE: Problems with folders ?
So just use the outline. If you don’t use the applet, you get an HTML table that you can play with to your hearts content in the browser – there is absolutely no reason to “get” the structure at the server. Why does everyone insist on doing things the hard way?
