Problems with displaying images (load time)
hi, we have upgraded a server to release 6.0.1 but there are problems with displaying images.
some images won’t get displayed instantly and i have to reload the window or select show picture with my right mouse click :frowning:
the applications running on another server (r5) show no problems with displaying images.
the images are a combination of image resources and images attached in documents…
can i set the interval for loading images to a greater value or something?
thanks in advance,
Patrick Kwinten
Subject: problems with displaying images (load time)
Hi Patrick.Currently we’re experiencing the same problem. server version is 6.0.1.
What we found out is: this problem only occurs with IE6.0 SP1 and not with earlier versions (incl. IE 6.0)
What about you?
Cheers Reto
Subject: RE: problems with displaying images (load time)
Hello,I upgraded to 6.01. On user work stations for the mails with images they can only see place holders. For the same mails on the administartor work station they appear okay.
What could be the problem.
Any clue will help
Thank you
