Problems with Client mailbox
We upgraded our main Notes Server to 6.0.1 but we left all other Servers at 5.0.11. (All Servers are W2K) All clients are 5.0.3, 8, 9 or 11. (Clients are on Win9x and WinNT)
1.After the upgrade, some users had some of their e-mails show up in the Inbox as well as a subfolder they had created and moved them to.
2.Some users have e-mails that show up only in the all documents view. (this happened before the upgrade)
Any idea what caused either issues and how to fix them?
Subject: Problems with Client mailbox
Which mail template version are you using? What Domino version is running on the MAIL Server of the user who had the problems? I would suggest to refresh the design of the mail template or even to replace the design with the apropriate mail template. Good luck!
Subject: RE: Problems with Client mailbox
Most users are using the inotes5.ntf template. Mail Server is 6.0.1. I replaced the client mail design with inotes60 and still have the problem. For this user it looks like only mail between May 2002 and October 2002 are affected.
I have exactly the same problem
My users were on a domino server 5.0.7A and i noticed after the problem occured that there were no compact task running on their mailboxes .
I replicated their mailboxes on a Domino 6.0 server with Linux
Their message in folders reappears in the inbox folder which is a lot of trouble to them
If anyone has information to explain and solve this, thanks for it
Meanwhile I discovered the following: I installed Domino 6.0.1CF1 global English, then I ADDED the German language pack. I had problems converting the users mail files, the inbox was empty. I removed the German language pack and then REPLACED the English version with the German version. The convert was working fine. The mail was kept in the inbox.
