Hi to all! I try to use C++ API Toolkit with Domino 6.5 under Linux. When I try to compile a dbtitle example I’ve got the error above.Another undefined reference is for ‘re_comp@noteslib_v1.00’.
Tried to replace header files with newer from 6.5 C API toolkit - no effect.
Does anyone have the same problems? Is there any workaround?
Thanx for help.
Subject: Problems with C++ API Toolkit: libcpplin.so.23 - undefined reference to ‘re_exec@noteslib_v1.00’
Got the same pb with 6.5, cpp toolkit 2.4 under suse 9.0.Any lead ?
If it can help you see my post :http://www-10.lotus.com/ldd/nd6forum.nsf/DateAllThreadedweb/120f1a542ab619dd85256e1d0040a0ec?OpenDocument
