I am trying to install Notes 6.5.4 onto a Mac running OS X 10.4.1. An additional note is that the hard drives have been formatted as “Mac OS Extended (Case-sensitive, Journaled)” (I would assume that most systems are formatted case-insensitve). I have done a clean install to the default locations on the machine.
After setting up the connection information for Notes, I end up getting a “Bookmark file does not exist” error and the program exits after I click “OK”. When I try to login again, I enter my password and the message pops up.
I was able to copy the bookmark.nsf file from a previous install of Notes, but now I get the error:
“The Notes 6 Client requires an up to date bookmark template, BOOKMARK.NTF. Please obtain a copy and restart Notes.”
I’ve tried copying the ntf file from my old install as well as from a Windows version with no luck.
Has anyone seen this problem and have a solution that would help me get Notes up and running?
Subject: Problems with bookmark.nsf & bookmark.ntf
Well, I solved my problem with this by reformatting my hard drive without the case-sensitive option and re-installing Tiger and Notes. Looks like Notes has issues with ‘case-sensitve’ disk formats (too much Windows heritage I guess). I’ll attempt to turn in a bug report for this.
We had the message trying to put the test id’s on and complete the install in our training room after the tech support person started the install, stopping signing off after just putting on the files. You have to have admin rights to the machine to finish. Changed to come in as admin and it worked great. Maybe that’s your problem too.
Subject: RE: Problems with bookmark.nsf & bookmark.ntf
Deborah,I am set up as the administrator for my Mac, so this wasn’t the issue. I did go in a grant more privileges on the file so that anyone could modify the file, but that didn’t help either.
Thanks for the try though!
kevin
