Problems with arrays in LS, please help
Hi,at the moment I’m trying to code an agent that will delete all “$UpdatedBy” Fields from an database by copying all documents to a new version, removing the field, adding back referrers and saving the new document.
My code have some issues with setting the “$REF” fields into the right order, it seems both arrays in the first “for-loop” don’t get the UNIDs of the main documents so the later following “Arraygetindex” in the second “for-loop” can’t find anything to make a reference to. The Error I get in this line is “Type Mismatch”.
I hope you are able to understand what I like to achieve. Thanks for any help in advance.
Greets,
Marco
Code starts here:
Sub Initialize
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim newdoc As NotesDocument
Dim collection As NotesDocumentCollection
Dim j As Integer
Dim i As Integer
Dim s
Dim item As NotesItem
Dim docUNIDs (1 To 1000) As String
Dim newdocUNIDs (1 To 1000) As String
Dim valueArray
Dim ref As NotesItem
Set collection = db.AllDocuments
For j=1 To collection.Count
    Set doc = collection.GetNthDocument(j)
    If (Not doc.IsResponse) Then
        docUNIDs(j) = doc.UniversalID
        Set newdoc = New NotesDocument( db )
        Call doc.CopyAllItems( newdoc, True )
        newdocUNIDs(j) = newdoc.UniversalID
        Set item = newdoc.GetFirstItem("$UpdatedBy")
        If (item Is Nothing) Then
            Call newdoc.Save(True,False)
            Call doc.RemovePermanently( True )
        Else
            Call item.Remove
            Call newdoc.Save (True, False)
Next
For i=1 To collection.Count
    Set doc = collection.GetNthDocument(i)
    If (doc.IsResponse) Then
        Call doc.CopyAllItems( newdoc, True)
        Set ref = doc.GetFirstItem("$REF")
        valueArray = ref.Values
        s = Arraygetindex( docUNIDs, valueArray )
        Set ref = New NotesItem( newdoc, "$REF", newdocUNIDs(s) )
        Else
            Call item.Remove
Next
Subject: Problems with arrays in LS, please help.
Thanks for your suggestions, I incorporated the first one like the code in this posting.
The second suggestion seems to be much easier I thought about this first but for one thing I wasn’t sure. Good reminder I’ll try this too.
If anyone can make some suggestions or notices about my code please add your comments.
Greets,
Marco
Code so far (not working):
Sub Initialize
Dim responses As NotesDocumentCollection
Dim j As Integer
Dim i As Integer
Dim s
Dim valueArray
        Else
            Call item.Remove
Next
Set responses = db.AllDocuments
For i=1 To responses.Count
        'Set ref = doc.GetFirstItem("$REF")
        'valueArray = ref.Values
        s = Arraygetindex( docUNIDs, doc.ParentDocumentUNID)
        'Set ref = New NotesItem( newdoc, "$REF", newdocUNIDs(s) )
        Call newdoc.MakeResponse( db.GetDocumentByID(newdocUNIDs(s)) )
        Else
            Call item.Remove
Next
Would it be far better to set the advanced database options? Just set it like below (see last two properties on the last property tab of the db) and the updated fields will shrink to one entry, which they would with your approach as well, then touch every document and save it.
Subject: RE: Problems with arrays in LS, please help.
I tried your suggestion with this code and the two options set to “1” but still the “$UpdatedBy” Fields don’t change better reverse to just one entry.I used this code:
Sub Initialize
Dim i As Integer
	Set doc = collection.GetNthDocument( i )
	Set item = doc.ReplaceItemValue( "Cthulhu", "Fhtagn" )
	Call doc.Save( True, False)
	Call doc.RemoveItem( "Cthulhu" )
Next
How about this instead?
	Set item = doc.RemoveItem( "$UpdatedBy" )
	Set item = doc.RemoveItem( "$Revisions" )
My recollections was that you could remove those fields and then they would be recreated with just the latest entry, but that may have been through the C API and not through LotusScript.
heay Marco
you can get & set values from reserved fields in the following way
refValue = doc.~$Ref(0)
doc.~$Ref = refValue
Trying doing this way… and still you have a problem pls create a dummy db and send it to me I shall fix it up for u :slight_smile:
Cheers
KV
karpagavinayagamkp@in.ibm.com
Marco
Forgot to add the following line in my previous post.
I am giving you a generic function which will update the $updatedBy field from the source to target. Go thru this function it should help you.
Function changeFieldValue(sourceDoc As notesdocument,targetDoc As NotesDocument)
Dim arrUpdatedBy()
Redim Preserve arrUpdatedBy(Ubound(sourceDoc.~$UpdatedBy))
For i = Lbound(arrUpdatedBy) To Ubound(arrupdatedBy)
	arrUpdatedBy(i) = sourceDoc.~$UpdatedBy(i)
Next
'now put the arrUpdatedBy array to the $updatedBy field in your target document
targetDoc.~$UpdatedBy = arrUpdatedBy
Call targetDoc.Save(True,True)
End Function
Marco
Dim arrUpdatedBy()
Next
End Function
I haven’t studied your code in depth, but I would suggest that rather than manipulating the $REF field directly (dangerous IMHO) you consider using
notesDocument.ParentDocumentUNID
and
notesDocument.makeResponse(newParentDocument)
HTH - Rufus.
