Problems when i'm trying to apply a policy
Hello everyone.
I’ve created an explicit policy over the Domino administrator, everything seems to be OK when i save it, but i have a little problem when i apply it into a user…the problem is that nothing happens. In this case, my policy aims to change the encryption configuration for an user, but when this user opens his Notes client, the change that i want to make isn’t applied, so, the policy doesn’t work at all…
Where would be the problem?
Regards.
Nestor Nazer
Subject: Problems when i’m trying to apply a policy
On the users’s PC, in their local Address Book, press and hold CTRL+SHIFT, then click on View → Go To, and look at the $Policies. Does the new policy show up there? Even better, delete all the policies such that they are no longer there and will be applied next time user connects.
Also, have you run a policy synopsis on the user to determine what policies are applied and how they impact the user?
I can’t recall it, but there is something that runs on the client side to do this. If this isn’t running, it could be why the policy is not being applied.
Brian
Subject: RE: Problems when i’m trying to apply a policy
Thanks Brian for your help, i hope that this problem will be solved in the next clients log in
Also from Gregg’s blog
From the abstract:
This document is part of a collection of documents designed to help administrators better
understand how to create, configure and troubleshoot Lotus® Domino® policies. The topic
of this document, which includes an accompanying video, is troubleshooting policy
settings documents.
http://www.ns-tech.com/blog/geldred.nsf/plinks/GELD-7E769P
JYR:
LOL! Good thing I read through the responses, I was just getting ready to post the link. :slight_smile:
Gregg
I’m faster than you :slight_smile:
JYR
