Problems using pernames(contacts)...sort of
Hi!A common trick to see all views in a db used to be old ctrl+shift+ right click and then Application- Go To, however this doesnt seem to work in the personal names.nsf i N 8.5.
I manage to see all views in the dialog-box, but it always fails to open the choosen view.
My template is v. 8.5 dated 2008-10-21.
I want to delete some policies in my local Contacts(pernames).
You can open the same pernames in N7.x
Has anybody seen this?
And solved it?
