Problems trying to open more than 1 file
Im having this message when i try to open more than 1 file in my lotusscript agent:
File already open (in the last line of the following code)
The names of the files are diferent!!
My code:
Dim fileControl As Integer
Dim fileNum As Integer
Dim file1 As Integer
Dim file2 As Integer
file1% = Freefile()
file2% = Freefile()
	fileName$ = nomearquivoSolicitacaoVIAGEM & ".xml"
	fileControl = 2
	nomeArquivo = fullpath & nomearquivoSolicitacaoVIAGEM
	OutputFile1 = nomearquivoSolicitacaoVIAGEM & ".xml"
	FileExists = Dir$( OutputFile1, 0 )
	While FileExists <> ""
		OutputFile1 = nomearquivoSolicitacaoVIAGEM & " (" & fileControl & ").xml"
		fileControl = fileControl + 1
	Wend
	Open OutputFile1 For Output As file1%
	fileName$ = nomearquivoPrestacaoVIAGEM & ".xml"
	fileControl = 2
	nomeArquivo = fullpath & nomearquivoPrestacaoVIAGEM
	OutputFile2 = nomearquivoPrestacaoVIAGEM & ".xml"
	FileExists = Dir$( OutputFile2, 0 )
		OutputFile2 = nomearquivoPrestacaoVIAGEM & " (" & fileControl & ").xml"
	Wend
	Open OutputFile2 For Output As file2%
Any ideas? Thanks =)
Subject: Problems trying to open more than 1 file
I’d lean toward the problem having to do with files being left open.Try using FreeFile() for consistent new values and forcing a close # when completed.
Collin
KC8TKA
