Problems synchronizing names.nsf with XTND Connect PC 4.9
Hi!
I have a problem synchronizing the personal adressbook between my cellphone and notes6. The calendar goes without problems but names.nsf don´t. Extended systems homepage says that 4.9 would support Notes6. “Unable to open database, Title: Server: Local Filename: C:\Notes6\Data\names.nsf”
Anyone knows how to solve this issue?
//Claes
Subject: Problems synchronizing names.nsf with XTND Connect PC 4.9
Hi, I use 5.1 (ES) to sincronize LN 6.0.2 with SE Z600.
The Z600 only support 500 contacts, so I filtered some contacts, using a value in Category field. Something like “Celular”. This works fine.
But other problem is with LN 6.0.2 and a Palm m505.
I hope, this help you.
Regards
