I have tried to set secure console password on a domino 6.5 server but I have a problem:
If I try to restart the server, I must type on the console: restart server [password], and it works correct.
But if I try to restart HTTP task, and even if I type “tell HTTP restart” or “tell HTTP restart [password]”, it doesn´t work and next and I can see this message on the console:
“this command is not permitted when console security is in effect”
Does anybody know a way to restart HTTP task typing a command at a password protected server console?
I know I can restart HTTP task using the administrator client, but I want to know if I can do it directly at server console.
