Problems recieving smtp-mails
Hello!
We have Problems recieving mails from different smtp-servers.
When the server recieves (Domino 6.0.1 cf1) mail from e.g. epost.de it’s always the same. The Server connects with our server and nothing happens.
With mst other servers it works, but from some servers we can get no mail…
Here is a Part of our Server-Log:
22.04.2003 20:54:37 SMTP Server: 193.28.100.187 connected
22.04.2003 20:54:38 SMTP Server: Originator: stefan.hippeli@epost.de
22.04.2003 20:54:38 SMTP Server: Recipient: michel@hippeli.de
22.04.2003 21:00:00 SMTP Server: 193.28.100.187 disconnected. 0 message[s] received
22.04.2003 21:14:26 SMTP Server: b.ls.adjoli.net (80.190.100.70) connected
22.04.2003 21:14:27 SMTP Server: Originator: targetcard7-return-5-michel=hippeli.de@newsmarketing.adjoli.de
22.04.2003 21:14:27 SMTP Server: Recipient: michel@hippeli.de
22.04.2003 21:19:50 SMTP Server: b.ls.adjoli.net (80.190.100.70) disconnected. 0 message[s] received
22.04.2003 21:20:40 SMTP Server: 193.28.100.187 connected
22.04.2003 21:20:40 SMTP Server: Originator: stefan.hippeli@epost.de
22.04.2003 21:20:40 SMTP Server: Recipient: michel@hippeli.de
22.04.2003 21:26:51 SMTP Server: 193.28.100.187 disconnected. 0 message[s] received
Every little help would be higly appreciated!
ByeBye
Michael
Subject: Problems recieving smtp-mails
have you created SMTP Inbound document?
Try to change your SMTP command settings. Disable them all and look if there’s any improvement. The pipelining extension command can sometimes give such problems. Search this forum too, this is a problem that’s often posted allready.
Subject: RE: Problems recieving smtp-mails
I tried different settings, but nothing worked…
Now i set SMTPDebug to “3”. It’s strange, but the server connects and after the DATA-Command comes a timeout-error.
This only happens, when the mail has an attachment.
24.04.2003 17:59:04 SMTP Server: Originator: stefan.mueller@epost.de
24.04.2003 17:59:04 SMTP Server [04E4:000A-07D4] Processing in Connected state
24.04.2003 17:59:04 SMTP Server [04E4:000A-07D4] RCPT command received
24.04.2003 17:59:04 SMTP Server: Recipient: michel@TESTCOM.de
24.04.2003 17:59:04,46 [04E4:000A-07D4] SMTP CITask StateMachine> Received 4 bytes from 193.28.100.187
[04E4:000A-07D4] R: DATA
24.04.2003 17:59:04,46 [04E4:000A-07D4] SMTP CITask StateMachine> Sent 53 bytes to 193.28.100.187
[04E4:000A-07D4] S: 354 Enter message, end with “.” on a line by itself
24.04.2003 17:59:04 SMTP Server [04E4:000A-07D4] DATA command received
24.04.2003 18:04:55,17 [04E4:000A-07D4] SMTP CITask RecvErrorHandler> ERROR: (193.28.100.187) Receive failed (did not timeout), error = 0A02h (Remote system no longer responding)
24.04.2003 18:04:55,17 [04E4:000A-07D4] SMTP CITask RecvErrorHandler> Running default hanlder, error = 0A02h (Remote system no longer responding)
24.04.2003 18:04:55 SMTP Server: 193.28.100.187 disconnected. 0 message[s] received
Has any progress been made with this issue?I have been working through the same issue and have yet to resolve it, even after trying all suugestions posted so far.
