Problems opening db w/ agent
Hello,
When running my code I get the following error (database \dbname has not been open yet).
here is a piece of my code;
Dim db As New NotesDatabase “” , “mailbox.nsf”)
Dim view As NotesView
Set view = db.GetView (“Date Collection”)
Dim doc As NotesDocument
'Dim temp variables
Dim vMth As Variant
Dim vYr As Variant
Dim vMthYr As Variant
Dim sMth As String
Do Until doc Is Nothing
vMth = Left(doc.GetItemValue(“DateComp”)(0),3)
vYr = Right(doc.GetItemValue(“DateComp”)(0),4)
vMthYr = vMth & vYr
sMth = Month(Today)
If sMth = “1” Then
If vMthYr = “Dec” & Year(Today) Then
Call doc.PutInFolder(“Dec” + Year(Today))
If sMth = “2” Then
If vMthYr = “Jan” & Year(Today) Then
Call doc.PutInFolder(“Jan” + Year(Today))
Set doc = view.GetNextDocument(doc)
Loop
Subject: problems opening db w/ agent.
After your first line, add the following:
call db.Open(“ServerName”,“DBName”)
This should do the trick I think. Before you can access certain properties and methods of a DB in LotusScript the DB needs to be opened, otherwise you get the error you referred to.
Hope this helps…
The most common reason for this error message is a security violation. So check the ACL for the effective user of the agent. To understand the security issues in agents, you might find Agnet FAQ articles about agents helpful. It also gives you example of some error handling code, and some tips on troubleshooting various common agent issues.
