Good day
I need some advice on partitioned servers.
WE had a Domino domain running smoothly for a couple of years, without any real problems. We had 4 servers running R6.5.2 running on Windows Sever 2003 Standard.
I had to setup a complete new domain after a merge with another company.
I installed a second domino server on the same box, for every existing server. Everything completely separate from the existing domain. So we now have 2 domains running next to each other, with different organizations, different internet domains.
I installed 2 network cards in each box. Each partition got its own NIC and IP address.
I haven’t changed anything on the existing domain, except for installing Patch 3 for Service Pack 3 for Trend Micro’s ScanMail for Domino.
My problems are:
1.One of the servers in the existing domain keeps on brining up the following error every 3 days or so.
007/10/24 12:47:29 PM The TCP/IP protocol stack reported that it ran out of memory. Consult your network documentation to increase configured memory, or reduce Notes connections by limiting clients (see SERVER_MAXSESSIONS parameter in Notes Admin Guide). - Automatically reducing TCPIP port maximum sessions to 36. Currently, 4 sessions are in the process of being recycled.
When the error appears on the console, no one can connect to the server. TCP/IP stops completely. The server is used as a file server, users can’t access their files. I cannot even ping the server. The only way to get everything back to normal is to stop the Domino server and restart Windows.
2.On the new domain I have on server running as our SMTP server. Routing mail to and from the internet. If I send mail from a client, who’s home server is the SMTP server, to an internet address the mail will go out to the internet with out any problems. But when I send an email to the internet from a client who’s home server is one of the other servers in the domain, I get the following error:
2007/10/24 07:21:34 PM No route found to domain yahoo.com. Check Server, Connection and Domain documents in Domino Directory.
Any help on this will be appreciated.
Thanks in advance
Leon
