Problems installing Traveler 11.0.1 on SUSE 15SP1
Hi everybody,
I tried unsuccessfull to install Traveler 11.0.1 (Traveler_11.0.1_Linux_ML.tar) on a brand new Domino 11.0.1 server in a SUSE 15 SP1 linux server.
The installation seems to be successfull but the Traveler task start and immediatly stops with the following error
07/08/2020 10:47:12 Traveler: Server starting...
07/08/2020 10:47:13 Traveler: SEVERE *system Error starting a Transaction Exception Thrown: java.sql.SQLException: Failed to create database 'ntsdb', see the next exception for details.
07/08/2020 10:47:13 Traveler: SEVERE *system Exception Thrown: com.lotus.sync.db.PersistenceException: com.lotus.sync.db.PersistenceException: java.sql.SQLException: Failed to create database 'ntsdb', see the next exception
07/08/2020 10:47:13 Traveler: SEVERE *system Unable to connect to database. Verify the database is running and that the database configuration is correct. Use travelerUtil to modify configuration parameters as necessary. Exception Thrown: java.sql.SQLException: Failed to create database 'ntsdb', see the next exception for details.
If somebody has an idea it will be very appreciated
thanks
ciao
tommaso
Hello
The message indicates that the traveler task could not connect to the SQL database.
So can you check if the database server you configured during setup is up and running ?
Regards
Mathias
Hello Ciao,
If your Traveler server is a Standalone server, can you try running below command and check if it helps
load traveler -defrag
If this does not help, can you start the traveler with below command and share the output
load traveler -debug
Are you using an external DB2 or MSSQL server? Or are you using the default Derby database? If Derby, perhaps your SUSE15 system is running into an issue we have seen on a newer RHEL8 system: the default LANG might be set to "C.utf-8" or some similar string, but the level of Derby shipped with Traveler expects LANG to be set to a value that looks like xx_YY where xx is a language code and YY is a country code. Check the value in /etc/locale.conf, if it is C.utf-8 try changing that to "en_US.UTF-8" and reboot.
Hi Tom, you got it!
We changed LANG from C.UTF-8 to en_US.UTF-8 and Traveler comes up like a charm
thanks a lot
tommaso
(i wonder how did knew that ...)
