Hello,
if I want to open my inbox with Domino 6.5 and inotes-template with IE I get the error:
error encountered fetching data.
The same with all folders and all views.
Only opening a new memo is working fine.
We have migrated from Domino 6.0 on Linux to Windows 2003 (just copying the data directory to Windows). Everything is working ok (mail routing, Pop3, LDAP, Web-Access to Mail db with simple design) apart from the inotes web access.
I tried everything:
changing the names.nsf
renaming the notes-directory (binaries) and reinstalling the server
renaming the notes\domino directory and reinstalling the server
renaming the java directory and reinstalling the server
The only thing I haven’t tried (because it is a little bit complex) is installing the server from scratch.
Any ideas, which files or databases (probably linux files) cause this problems?
Thank you
Manfred
