Hi,I am facing problems while Copy Pasting Text from MS Word to Rich Text Field in Lotus Notes.
When i paste the Following:
RECOMMENDATIONS / ACTIONS TAKEN:
From MS Word to Lotus Notes, It comes as this.
RecommendationS / aCTIONS TAKEN:
Any suggestions as to why this is happening or how to resolve the issue. Help would be Highly Appreciated.
Thanks in Advance.
Regards,
Jawad Rana
Subject: Problems Faced while copying Text from Word Document into RichText Field.
It sounds to me like the text you were copying had an “all caps” style applied to it in Word. That is, the actual text you copied was a mix of upper- and lower-case, as iy came out in Notes, but that the font style for that paragraph instructed Word to display the text in all upper-case.
Subject: RE: Problems Faced while copying Text from Word Document into RichText Field.
Well if you dont need advanced formating, you can try to copy from word to notepad and then to notes.
That won’t help if the text is mixed-case with an “all caps” style, since the actual text being copied is not all capital (uppercase) letters – it’s just being displayed and printed that way.
