Problems embedded applet view Designed on R6 works R5
Hi forum:
I have a embedded applet view developed on Domino 6 this database works over internet on Domino 5.0.8 and the access to the database is from IE 5 or 6 and the applet doesn’t work, don’t initialze the subprogram, this is the error:
cargar: clase lotus.notes.apps.viewapplet.ViewApplet.class don’t found.
java.lang.ClassNotFoundException: lotus.notes.apps.viewapplet.ViewApplet.class
at sun.applet.AppletClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadCode(Unknown Source)
at sun.applet.AppletPanel.createApplet(Unknown Source)
at sun.plugin.AppletViewer.createApplet(Unknown Source)
at sun.applet.AppletPanel.runLoader(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.IOException: open HTTP connection failed.
at sun.applet.AppletClassLoader.getBytes(Unknown Source)
at sun.applet.AppletClassLoader.access$100(Unknown Source)
at sun.applet.AppletClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
… 10 more
Any answer is welcome. Thanks
