Hello everyone,
In a notes database i use a form where i have created a HTML button(passthru HTML), which in turn calls a function. For e.g. My button code is as below:
Now on the same form’s JSHeader i have put the following code:
function triggerFunction(){
var xmlHttp=false;
try {
xmlHttp = new ActiveXObject(“Msxml2.XMLHTTP”);
} catch (e) {
try {
xmlHttp = new ActiveXObject("Microsoft.XMLHTTP");
} catch (e2) {
xmlHttp = false;
if (!xmlHttp && typeof XMLHttpRequest != ‘undefined’) {
xmlHttp = new XMLHttpRequest();
// build the url to connect to
var url=“http://www.igotthisone.com/sindex.html”;
//open a connection to the server
xmlHttp.open(“POST”,url,false);
//check xmlhttp ready state and url status
if (xmlHttp.readyState==4) {
if (xmlHttp.status==200) alert(“URL Exists!”)
else if (xmlHttp.status==404) alert("URL doesn't exist!")
else alert("Status is "+xmlHttp.status)
xmlHttp.send(null)
Iam just checking whether an URL exists or not !
now the problem is, when the execution reaches xmlHttp.Open method, An error is generated.
The error being generated is : uncaught exception: Permission denied to call method XMLHttpRequest.open
Ive detected this error using FireBug in FireFox. In IE neither ive got an error, nor ive got any response !
I have MSXML 4.0 SP2 and MSXML 4.0 SP2 Parser and SDK installed on the system.
What could be the cause for this error? Is it something to do with any settings in the Server document ? Or any kind of Database ACL settings? or something with the MSXML Parser/Version?
Help on this much apprecated !
Thanks in advance,
Jason.
