Problem with WebService API call
one function of this web service is to download an xml file. I call URLDownloadToFile from the MS urlmon dll to do this (thanks to an earlier post by Andrei K). Problem is that it returns error code “-2147221020” and the file is not downloaded.
Here’s a code extract >
Declare Function URLDownloadToFile Lib “urlmon” Alias “URLDownloadToFileA”(_
Byval pCaller As Long, _
Byval szURL As String, _
Byval szFileName As String, _
Byval dwReserved As Long, _
Byval lpfnCB As Long) As Long
result = URLDownloadToFile(0, FileURL$, NewFilePath$, 0, 0)
When I run the same lotusscript in an agent, it works a treat!!
So I suspect it’s a WebService/API quirk or something up with the MSSOAP configurations. I searched the web but found no obvious solution. Both the WebService and the test agent have the same security settings.
Any ideas are much appreciated.
Cheers,
Alan.
