I have a web enabled database. The problem is i have a link on my form, when i click on that link its givig a message “HTTP Web Server: Lotus Notes Exception - Entry not found in index”. Can anyone let me know how this can be resolved. Thanks in advance.
Subject: Problem with web based appliaction
Hi
Is that link your referring is a external URL. Or points to the url in the database itself
I guess this error is due to missing of some design elements may be
- you have misspelled the design elements name
2 )Or the design element is missing
3 )Does it has any images & the images are not in the database
Could u provide me what is there in the link
Subject: RE: Problem with web based appliaction
Hi Shobana,
This is the URL
http://TestServer.com/apps/Example.nsf/Content/AD7BE06A6584ACA48025721800661AB5?OpenDocument
Here, “Content” is the view name followed by DOC id
Hi Narsimha,
Are you sure that document usually appears in that view? Try the URL to see if that’s the problem-
http://TestServer.com/apps/Example.nsf/0/AD7BE06A6584ACA48025721800661AB5?OpenDocument
Cheers,
Andrew.
