Problem with Web Agent
I’m running into a problem with an agent I created. This agent basically takes the information from a form and sends it in an email after it is saved. I have the form and agent working on the client, however after throwing in some error trapping, I noticed that the agent for some reason isn’t processing right on the web. I’m creating a Nab view to pull the email addresses of where the email should be sent, based on a field chosen in this form, however based on the error trapping I put in, it’s not even finding the view or matching the keyword to the view. Here’s the agent. I’d greatly appreciate any help!
Sub Initialize( )
Dim db As NotesDatabase
Dim mailDoc As NotesDocument
Dim nameItem As NotesItem
Dim doc As NotesDocument
Dim lookupStr As String
Dim nabDb As NotesDatabase, nabView As NotesView
Dim nabDoc As NotesDocument
Dim FormName, FromName As String
Dim SubjectName, SendToName As String
Dim nam As NotesName, nameStr As String
Dim CopyToName As String
Dim rtItem As NotesRichTextItem
lookupStr = doc.GetItemValue("applications")(0)
Set nabDb = session.CurrentDatabase
Set nabView = nabDb.GetView("(AppData)")
Set nabDoc = nabView.GetDocumentByKey(lookupStr)
If Not(nabDoc Is Nothing) Then
	Set nameItem = nabDoc.GetFirstItem("manager")
	'Set nam = nameItem.Values("manager")
	Forall x In nameItem.Values
		nameStr = Cstr(x)
	End Forall
	Set nam = session.CreateName(nameStr)
	If doc.GetItemValue("status")(0) = "New" Then
		FormName = "Memo"
		FromName = doc.GetItemValue("filed_by")(0)
		SubjectName = "New Access Change"
		SendToName = nam.Common
		Set mailDoc = db.CreateDocument
		Set rtItem =mailDoc .CreateRichTextItem("Body")
		With rtItem
			Call .AppendText("There is a system access change request.")
			Call .AddNewline(2)
			Call .AppendText(doc.filed_by(0) + " filed the following system access change: " + doc.change(0))
			Call .AddNewLine(2)
			Call .AppendText("Employee: " + doc.employee(0))
			Call .AddNewline(2)
			Call .AppendText("Application: " + doc.applications(0))
		End With
		With mailDoc
			.Form = FormName
			.From = FromName
			.Subject = SubjectName
			.SendTo = SendToName
			.Send(False)
		End With
	Else
		FormName = "Memo"
		FromName = "Mark Rankin"
		SubjectName =  " Access Change Update For: " + doc.GetItemValue("employee")(0)
		SendToName = doc.GetItemValue("filed_by")(0)
		CopyToName = nam.Common
		With rtItem
			Call .AppendText("The following system access change request has been completed.")
			Call .AddNewline(2)
			Call .AppendText("Access Change: " + doc.change(0))
			Call .AddNewLine(2)
			Call .AddNewline(2)
		End With
		With mailDoc
			.Form = FormName
			.From = FromName
			.CopyTo = CopyToName
			.Send(False)
		End With
Else
	With rtItem
		Call .AppendText("There is a error with system access change request application.")
		Call .AddNewline(2)
	End With
	With mailDoc
		.Form = "Memo"
		.From = "mrankin@rpminc.com"
		.Subject = "Error"
		.SendTo = "mrankin@rpminc.com"
		.Send(False)
	End With
Subject: Problem with Web Agent
Are NabDb and DB supposed to be getting set to the same database? It looks like you are getting the same database three times … is it getting the correct database for that view?
How are you calling/processing the agent? remember that you cannot use QuerySave or Postsave events on the web. You either have to call the agent from the WebQuerySave event or as a scheduled agent. I recommend the latter so web performance is not impacted.
I see a problem here that your “NabDB” and your DB are both being set to Session.CurrentDatabase.
I have a feeling that you want your NabDB to bet set to something else like:
Set NabDB = New NotesDatabase(“names.nsf”) (I’m guessing that by “nab” you’re talking about a Name & Address Book / Domino Directory.)
If you’re looking for a view that doesn’t exist…then you’re going to have an undefined object.
