Problem with views in Webpage
i have the following problem:
I created a site where you can find some views integrated (embbeded view). Because the site have to be in HTML and no Java-Applets i have set the views to be in HTML.
If i use the Notes Client all views are shown. (at the moment 2) But in the IE only one view-field is shown (always the first one).
is there anyone who have an solution for that?
thx in advance
Subject: Problem with views in Webpage
Gerber,
Domino will only show the first embedded view when previewed in web pages.
To overcome this, create a iframe and then set the source to the second view which you wanted to display.
Like -
Subject: RE: Problem with views in Webpage
Thank you very much for your suppport. I will try.
