Problem with ViewBody
Hi
I have used $$ViewBody field on the form to display the view. But I have large number of documents so it is not displaying at one page. Can it be possible to increase the limit of $$ViewBody or any other alernative.
I do not want to use Embedded View.
Subject: Problem with ViewBody
With a $$ViewBody, you need to include a Count in the URL (a Count field will also work). But why not an embedded view? It’s much more versatile and controllable – $$ViewBody has really been a search-only solution since R5.
Subject: RE: Problem with ViewBody
but count did not solve my purpose. I have used it but it is not showing all the documents.
