Problem with view Column formula
I have the following column formula :
@If(DepartureDate1 = “” ; AccDepartureDate1 ;DepartureDate1 ;
DepartureDate1 = “” & AccDepartureDate1= “” ; “Unknown”)
The syntax is accepted ok, but the column results return , “Error Invalid data type for operator” all the fields are Text.
Can i have the & in a column formula ?? for text if not what fo i use ??
Subject: Problem with view Column formula
I don’t think the syntax is ok, because:
@If(DepartureDate1 = “” ; [this is your condition]
AccDepartureDate1 ; [this is the true branch]
DepartureDate1 ; [this is your second condition?] <======
DepartureDate1 = “” & AccDepartureDate1= “” ; [this is your second true branch]
“Unknown”) [this is the last false branch]
