Problem with upgrade of an application
We have a situation where we have developed some new functionality in a "sandbox" (e.g. updated access rights, steps and roles). Once Ok we selected the production site and chose to upgrade....
After a looooong time where it said "upgrading" it came up with a dialog saying that the application did not upgrade and there was an error on upgrading the application.
I have just tried it again using an exported volt file of the application prior to the upgrade - and the volt file used to upgrade.
This is very concerning as in our real environment we could not get near the database afterwards. In my recent test the database was still functioning...
  • What could be the reason for this?
  • How can we fix it?
  • What can we do to avoid it in future?
We are running on Volt 1.0.1 (I've seen that 1.0.2 has been released since this problem occurred)
Thanks in advance.
/John
How many submitted records are in the application?
Did the exported volt upgrade properly?
Did you check the Domino logs to see if it provided any insight into the upgrade failure (i.e. ...\DominoServer\data\domino\workspace\logs)?
When you clicked Upgrade, did you check the box to replace the data?
If you have a lot of data, you are probably hitting a bug in 1.0.1 where the deployment was exceeding the number of transaction locks allowed.
If you can upgrade to 1.0.2, I strongly suspect that your upgrade will be successful.
If you can't upgrade to 1.0.2 at this time, and if the logs Chris requested don't indicate a differrent problem, we can look for a workaround.
Sorry, our spamfilter provider made some changes that have kept me busy all day - fixing mail....
The messages I received when trying to update were:
2020-12-09T22:39:23.068+01:00SEVEREError deploying application with appID = 42958ae2-1713-4f20-8080-fcb472e2f451, Last successful action:design elements generated dleap.impl.service.DApplicationDeployerService
2020-12-09T22:39:39.193+01:00SEVEREError deploying application with appID = 42958ae2-1713-4f20-8080-fcb472e2f451, NSF changes rolled back. dleap.impl.service.DApplicationDeployerService
2020-12-09T22:39:39.255+01:00SEVEREError deploying application with appID = 42958ae2-1713-4f20-8080-fcb472e2f451, ACL changes rolled back. dleap.impl.service.DApplicationDeployerService
2020-12-09T22:39:39.255+01:00SEVEREcom.ibm.form.platform.service.framework.exception.ServicesPlatformException: Fejl ved opdatering af feltdata for applikation: Bestillinger (Sandbox)com.ibm.form.platform.service.framework.exception.ServicesPlatformException: com.ibm.form.platform.service.framework.exception.ServicesPlatformException: Fejl ved opdatering af feltdata for applikation: Bestillinger (Sandbox) at dleap.impl.service.DApplicationDeployerService.deployToLatestInternal(DApplicationDeployerService.java:277) at com.ibm.form.nitro.service.deployer.ApplicationDeployerService.deployToLatest(ApplicationDeployerService.java:673) at com.ibm.form.nitro.service.deployer.ApplicationDeployerService.deployToLatest(ApplicationDeployerService.java:639) at com.ibm.form.nitro.service.archive.ApplicationUpgradeService.upgradeApplication(ApplicationUpgradeService.java:287) at com.ibm.form.nitro.service.archive.ApplicationArchiveService.upgradeApplication(ApplicationArchiveService.java:348) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Nativ
There really isn't a lot of data - perhaps around 1.500 docs.
When I tried to upgrade I did not include data. We're trying to get ready for a dev. & prod. environment using an empty volt app as a "template". A little annoying that it also upgrades the name... So one has to be careful.
I saw that 1.0.2 was released. I'll get that installed. It also fixes a couple of other issues (eg. print).
Will let you know if it fixes this as well.
Thanks!
1500 is actually enough documents to hit the issue in 1.0.1. All should be well with 1.0.2 from what I can see in the log.
