I have a view, the user selects a document(s) in a view and then clicks a button to create a schedule A invoice (response document) The problem is that every once and a while the $ref and parentID value that are set in the response doc are not correct. When this happens both the $ref & parentID will be the same but they will not be the UNID of any document in the entire database. If we search the entire db for the UNID the orphaned doc was given it does not exist. (I set up a special full text view with every doc every created of every type just to be sure) The only record that will show up in the full text search is the orphaned response doc with that value in the parentID field. What could be intermittenly causing the MakeResponse and the parentID to be set wrong to some phantom UNID? I cannot duplicate the problem no matter how much testing I do. It works fine for me every time on my machine. Could it be a local client problem, there are reports of this one two machines and is intermittent on those machines? It seems to have flared up here in the last 30 days and we haven’t done anything to this agent/code at all. Though today it worked fine. I can post some sample UNIDs if that would help?
Here is the code:
Sub Initialize
Dim db As notesdatabase
Dim dc As notesdocumentcollection
Dim doc As notesdocument, doc2 As notesdocument, doc3 As notesdocument
Dim newdoc As NotesDocument
Dim DupLookupView As NotesView
Dim DupDoc As notesdocument
Dim DupDocId As String
Dim a1 () As String
Dim a2 () As String
Dim a3 () As String
Dim a4 () As String
Dim a5 () As String
Dim a6 () As String
Dim a7 () As String
Dim a8 () As String
Dim a9 () As String
Dim a10 () As String
Dim a11 () As String
Dim a12 () As String
Dim a13 () As String
Dim a14 () As String
Dim a15 () As String
Dim a16 () As String
Set db = session.currentdatabase
Set dc = db.unprocesseddocuments
Set doc = dc.getfirstdocument
If doc.Other(0) ="" Then
Other = "0"
While Not(doc Is Nothing)
'If doc.docPrefix(0) = "F" Then
'Messagebox "Your selection box highlighted an in house lease but you checked interest rate worksheets in the gutter. Reselect the worksheets while making certain the selection box is highlighting an interest rate based deal."
'Exit Sub
'End If
Set newdoc = db.CreateDocument
newdoc.Form = "Schedule A Invoice"
Call newdoc.MakeResponse(doc)
newdoc.parentid = doc.universalid
newdoc.InHouseBank = doc.InHouseBank(0)
newdoc.CusName = doc.CusName(0)
'newdoc.CusStreetAddress = doc.CusStreetAddress(0)
'newdoc.CusStreetAddress2 = doc.CusStreetAddress2(0)
'newdoc.CusSuite = doc.CusSuite(0)
'newdoc.CusCity = doc.CusCity(0)
'newdoc.CusState = doc.CusState(0)
'newdoc.CusZip = doc.CusZip(0)
newdoc.SalesMan = doc.SalesMan(0)
newdoc.Other = Other
IHTax = doc.IHTax(0)
IHToLeasePay = doc.IHToLeasePay(0)
IHTotal = doc.IHTotal(0)
IRInterimTotal = doc.IRInterimTotal(0)
IRInterimTax = doc.IRInterimTax(0)
newdoc.IHTotal = Cstr(IHTotal)
newdoc.IHCapRed = Cstr(IHCapRed)
newdoc.IHCapRedTax = Cstr(IHCapRedTax)
newdoc.IRInterimTotal = Cstr(IRInterimTotal)
newdoc.IRInterimTax = Cstr(IRInterimTax)
newdoc.IHTax = Cstr(IHTax)
newdoc.IHToLeasePay = Cstr(IHToLeasePay)
Set Doc2 = Doc
I = 0
While Not(Doc2 Is Nothing)
'If doc.InHouseBank(0) <> doc2.InHouseBank(0) Then
' Messagebox "The banks are not the same for all worksheets. The invoice will not be created. Reselect worksheets with the same bank."
' Exit Sub
'End If
'Lookup against active view to check for duplicate schedule A
DupDocId = doc2.DocNumConvert(0)
Set DupLookupView = db.GetView("(LookupScheduleAInvoice)")
Set DupDoc = DupLookupView.GetDocumentByKey(DupDocId)
If DupDoc Is Nothing Then
'Test
Else
Messagebox "Lease #: " + DupDocId + " has already been used on a Schedule A invoice. Either mark the existing Schedule A invoice inactive or repeat this process and do not select lease " +DupDocId +" ."
Exit Sub
If Doc.CusName(0) = Doc2.CusName(0) Then
Redim Preserve a1 ( 0 To I ) As String
Redim Preserve a2 ( 0 To I ) As String
Redim Preserve a3 ( 0 To I ) As String
Redim Preserve a4 ( 0 To I ) As String
Redim Preserve a5 ( 0 To I ) As String
Redim Preserve a6 ( 0 To I ) As String
Redim Preserve a7 ( 0 To I ) As String
Redim Preserve a8 ( 0 To I ) As String
Redim Preserve a9 ( 0 To I ) As String
Redim Preserve a10 ( 0 To I ) As String
Redim Preserve a11 ( 0 To I ) As String
Redim Preserve a12 ( 0 To I ) As String
Redim Preserve a13 ( 0 To I ) As String
Redim Preserve a14 ( 0 To I ) As String
Redim Preserve a15 ( 0 To I ) As String
Redim Preserve a16 ( 0 To I ) As String
a1(i) = doc2.DocNumConvert(0)
a2(i) = doc2.AutoYear(0)
a3(i) = doc2.AutoMake(0)
a4(i) = doc2.AutoModel(0)
a5(i) = doc2.AutoSxN(0)
a6(i) = doc2.ContractDate(0)
a7(i) = doc2.DriName(0)
a8(i) = doc2.Branch(0)
a9(i) = Cstr(doc2.IRInterimTotal(0))
a10(i) = Cstr(doc2.IRInterimTax(0))
a11(i) = Other
a12(i) = Cstr(doc2.IHTotal(0))
a13(i) = Cstr(doc2.IHTax(0))
a14(i) = Cstr(doc2.IHToLeasePay(0))
a15(i) = Cstr(doc2.IHCapRed(0))
a16(i) = Cstr(doc2.IHCapRedTax(0))
I = I +1
Set doc3 = dc.getnextdocument(Doc2)
Call dc.deletedocument(doc2)
Set doc2 = doc3
Else
Set Doc2 = dc.getnextdocument(Doc2)
Wend
newdoc.DocNumConvert = a1
newdoc.AutoYear = a2
newdoc.AutoMake = a3
newdoc.AutoModel = a4
newdoc.AutoSxN = a5
newdoc.CommencementDate = a6
newdoc.DriName = a7
newdoc.Branch = a8
newdoc.IRInterimTotal = a9
newdoc.IRInterimTax = a10
newdoc.Other = a11
newdoc.IHTotal = a12
newdoc.IHTax = a13
newdoc.IHToLeasePay = a14
newdoc.IHCapRed = a15
newdoc.IHCapRedTax = a16
Call newdoc.save(True,False)
Wend
