Problem with uidoc in QueryOpen
Hi,I have a problem where I’m trying to set a value of 0 in a numerical field using the QueryOpen option. My problem is that I get an “Object Variable not Set” error message when you try and open a document. Any Ideas? Please see my code below:
Sub Queryopen(Source As Notesuidocument, Mode As Integer, Isnewdoc As Variant, Continue As Variant)
Dim db As NotesDatabase
Dim uidoc As NotesUIDocument
Dim workspace As NotesUIWorkspace
Dim item As NotesItem
Dim session As NotesSession
Set uidoc = Workspace.CurrentDocument
est = uidoc.FieldGetText("estSRhrs")
If est = "" Then
	Call uidoc.FieldSetText(estSRhrs,0)
Else
Subject: Problem with uidoc in QueryOpen
Why are you using the NotesUIWorkspace to get the current document ??
You get it using the variable Source from the parameters…
A clean code would be :
est = Source.FieldGetText(“estSRhrs”)
If est = “” Then
Call Source.FieldSetText(estSRhrs,0)
Else
… the other code…
I saw sometimes problems with the kind of code your made, where notes doesn’t return any value for Workspace.CurrentDocument (especially when using frameset).
Using the Source variable, your sure to have the right document !
Hope this helps !
Renaud
U have missed the line
set workspace = New NotesUIWorkspace
Use the PostOpen event as the fields are not available yet in QueryOpen.
Don
