Go into the embedded view’s QueryOpenDocument event and see if you can use notesuiworkpace.currentdocument to read fields from the main form. Under certain circumstances, I do not remember just what, you can read field values on the main form from within an (embedded view? or) embedded editor.
Try the same thing from the secondary form’s QueryOpen event.
A variation on this idea: try opening the secondary documents in an embedded editor instead of in a new window, and see if you can read the main form from there. In this case, try reading notesuiworkspace.currentdocument (not Source!) from the secondary form’s PostOpen. I believe this one works. Not so sure about the other ones.
