Problem with the CalendarGoTo-command?!
Hello,
we want to change from Domino 7.0.4 to 8.5.2.
There is a problem in a Notes-application (only Notes-Client, no Web).
In a formula-button I used
@Command( [MailOpen] ) ;
@Command( [OpenFrameset] ; “CalendarFS” ) ;
@Command( [CalendarGoTo] ; @Date(Termin) );
It works fine in 7.0.4!
Now I get the message “Frameset ‘CalendarFS’ doesn’t exist.”
OK, I’ve tried
@Command( [OpenCalendar]; @UserName )
instead of
It works.
I think, there is a problem with the CalendarGoTo-command?!
It doesn’t work (@Command or @PostedCommand - it’s no difference)!
I searched in the 8- and 8.5-Forum and I found two similar entries:
… without a solution… :frowning:
Has anybody an idea?
Many thanks in advance!
Morena
Subject: LO44005: @COMMAND([CALENDARGOTO]) DOES NOT GO TO THE SPECIFIED DATE IN THE NOTES 8.5 STANDARD CLIENT
http://www-01.ibm.com/support/docview.wss?uid=swg1LO44005
“… The problem will be fixed in the next release of the product …”
Great! And what can we do in the meantime?!
Subject: Tracked under SPR DPOL7VKCTK
I would suggest opening up a PMR to drive getting this fixed
Subject: Where can I find the SPR? How can I open a PMR?
Hi Dave,
thank you for answering. I think you would like to help me?!
But in German I would say “Ich verstehe nur Bahnhof!” (translation for you: It’s all Greek to me!).
OK, in this forum I found the translation for the abbreviations ‘SPR’ and ‘PMR’:
"… If I recall, PMR stands for “Problem Maintenance Report” or something like that. SPR is “Software Problem Report”.
PMR = “I need help”, SPR = “This is a confirmed bug.” …"
http://www-10.lotus.com/ldd/nd85forum.nsf/5f27803bba85d8e285256bf10054620d/37c88f1be5be74958525754e006b76d3?OpenDocument
My questions:
  1. Where can I find the SPR “DPOL7VKCTK”?
  2. How can I “opening up a PMR to drive getting this fixed”?
PLEASE send me the links and more informations!
Regards
Morena
Subject: Info
To open a PMR I found a thread which describes what needs to be done http://www-10.lotus.com/ldd/nd85forum.nsf/5f27803bba85d8e285256bf10054620d/aee4d905a19a91d88525763c00245a4a?OpenDocument
I believe the only way to see the SPR from outside of IBM is in the release’s Fix List once it is resolved.
Subject: Service Request (new name for PMR i guess) created today
I has ID: 14000,999,678.and I have attached a Sample.nsf with an Action agent, for reproduction of the problem.
Subject: Did you have succes, making a PMR (out of an SPR) ?
I have the same problem, now in Notes 9.0.1FP3, so it sounds weird a so old problem still is unfixed ?Have searched myself, in this Fix Central: IBM Support: Fix Central
Be sure you have selected the SW family, first.
Subject: The SPR is not fixed
Just a quick confirmation that SPR DPOL7VKCTK is not fixed. The best approach is to open a PMR and refer to that SPR.
Subject: Thanks, I will.
Subject: Done. See above…
happened to create it under another reply…
